No power to thermostat .. Help!!
Old 01-10-18, 03:43 PM
Hello everyone.....
I was replacing the trim plate on my Ecobee3 when all of a sudden it stopped working. I've checked the wires, the breaker and the furnace and it seems that the furnace is getting power but not sending anything through the wires to the thermostat. Soo odd that it was working 2 days ago and not this.
Thanks
Old 01-10-18, 06:00 PM
A
Received 36 Votes on 32 Posts
You most likely shorted wires together and blew a fuse on the furnace control board.
Old 01-10-18, 06:27 PM
Received 935 Votes on 872 Posts
Welcome to the forums.
Agreed. Start by checking for an automotive type plastic fuse on the control board. If no fuse can be located you'll need to use a voltmeter to check for 24vac on the R and C terminals at the furnace.
Old 01-10-18, 07:02 PM
You guys rock and 100% right!! Problem solved!! Thanks again!
Old 01-10-18, 07:19 PM
Good job.
Just FYI..... be sure to use the same size fuse to protect the transformer from damage.
