Control Board Transformer Voltage
Old 02-09-18, 04:57 PM
Mirage's Avatar
Angry Control Board Transformer Voltage
Hi,
I have a furnace having issues and I noticed my Transformer is reading 29.5V output. The Schematic says it should be 24V. Is this a serious problem? Is too much Voltage a bad thing or can my furnace handle it just fine?
I'm thinking maybe the transformer is defective and it's outputting too much Voltage, and not enough current to 'drive' the rest of the circuit.
Old 02-09-18, 05:05 PM
Received 338 Votes on 316 Posts
That is ok. Your furnace board can handle that voltage.
For the most part.... higher wattage transformers run at slightly higher voltages.
If you check the voltage under operation.... it should come down some.
