Carrier Code 34 - Ignitor is glowing, no gas or ignition
Old 03-18-18, 09:06 AM
A
My carrier furnace decided it was a good time to stop working.
The furnace errors code 34, but my igniter is glowing
The gas valve doesn't seem to be activating and I am not sure what to do next
Any suggestions?
Model: 59TP5A080E171116
Old 03-18-18, 12:42 PM
Received 3,409 Upvotes on 3,059 Posts
Welcome to the forums.
You're going to need a voltmeter to check for 24vac to the gas valve when it should be opening. You will want to shut off the gas to the furnace during this testing. The link below is your manual and there are good diagnostic routines to follow based on your fault code 34.
One thing you can do is to remove and reinstall the large multiwire connection to the control board several times. This is usually a 9 or 12 wire plug and socket. It can become corroded and this will clean it.
Carrier-59TP5A-Installation-Manual.pdf
Old 03-19-18, 03:01 PM
A
Thanks for the reply
From Common to M I get -8 V dc then it drops to 0 V when it should be turning on.
From Common to H I get -8V dc then it drops to about -6V dc when it should be turning on.
I also got ~60 ohms on the igniter when measuring it.
the main board has a bunch of individual connectors i pulled and re plugged, no change.
Old 03-19-18, 03:04 PM
A
Attached are photos of testing
Old 03-19-18, 03:21 PM
A
update:
I found the ~9 pin connector
I pulled and re-plugged it
I also adjusted two small capacitors
Furnace is working
Thank you.
Old 03-19-18, 03:30 PM
FYI, that is 24 VAC not DC.
Old 03-19-18, 04:55 PM
Also.... when checking voltage to a part like the gas valve..... the measurements need to be made at the terminals on the valve. Not one terminal and chassis ground.
