Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Gas and Oil Home Heating Furnaces
Reload this Page >
Blower runs longer than normal. It will shut off right before the burner ignites
Old 03-21-18, 10:00 AM
6
My blower has started to run longer then normal. It will shut off about a minute before the burner ignites for a new cycle and the blower will turn on for this cycle but then run long after the burner has shut off.
Goodman Model GMH950703BXAC
Last edited by 66Randy; 03-21-18 at 12:00 PM. Reason: adding make and model of heater
Old 03-21-18, 10:11 AM
Post the make and model number and we can help you out.
Old 03-21-18, 10:38 AM
Received 3,415 Upvotes on 3,063 Posts
Welcome to the forums.
While you're down there checking for the model number...... check the air filter.
It almost sounds like you are describing an overheat issue.
Old 03-21-18, 12:01 PM
6
Goodman. Model # GMH950703BXAC
Old 03-21-18, 01:45 PM
Are you talking about the combustion blower or house blower? Are you getting LED flash code on the control board?
Old 03-22-18, 07:19 AM
6
The red LED is steady, not blinking and its the fan that runs. I removed the red thermostat wire and the fan turned off and if I pull the thermostat off the wall the fan will stop. It will still blow when I turn the system off at the thermostat.
Old 03-22-18, 10:36 AM
Looks like you have a bad stat.
