Blower/Fan cannot stop in furnace
Old 03-26-18, 01:18 PM
F
Hi,
I have an issue on my furnace. After temperature arrived, furnace stop 10 seconds and then restart without producing heat but blower/fan keep running hourly and hourly. Even though I set the temperature to the lowest, it keep producing cold air. Tried both mercury and digital thermometer but had same issue. Then I saw that there is a blue line that doe not connect to any part in my blower controller panel. Do I need to put the blue line into the vertical hole? Since the red line was put into horizontal hole.
Otherwise, anybody know why this happened? Thanks.
Old 03-26-18, 02:13 PM
If that is the blower relay then the blower should be off. What is the mode number on the furnace?
Old 03-26-18, 02:41 PM
F
The Model is: N9MSB*C1 & N9MSB0801716B2
Old 03-26-18, 08:43 PM
Received 1,615 Votes on 1,487 Posts
Welcome to the forums.
That is a relay in the corner. It's labeled on the board but I added clearer labeling. The two contacts are for the blower fan. Cooling speed is in the top and heating speed is in the bottom. I see you don't have A/C so the cooling wire isn't that important but you can slide the blue wire on the cooling terminal.
The blower for the furnace is controlled by a timer circuit on the control board. Since your blower is cycling when it shouldn't be..... it appears the board may be defective.
Old 03-27-18, 07:32 AM
F
Thank you, PJmax. I will ask for a technician to repair that.
