coleman dgaa070bdta gas furnace draft inducer
Received 0 Votes
This is my first post and I would like to thank you in advance for any advice.
As the post indicates, I have a coleman dgaa070bdta gas furnace. I decided to test run it and it would not start. I heard the click to start the draft inducer but the motor wouldn't kick in. I heard a hum that sounded like the fan motor was trying to turn. The flashing code was 3 green flashes indicating the combustion air switch failed to close. I ordered a new air switch and a new draft inducer. Hopefully I'm not just throwing parts at it... Your thoughts please.
If the draft inducer just hums..... that's most likely the problem.
Some have replaceable capacitors on the motor.
Some people take them apart.... clean and oil them. It may last a short while longer.
I've found it best to replace the inducer.
