furnace not working
Old 10-13-18, 03:06 PM
furnace not working
so i bought a house been fixing it up was told the furnace works really good now the cold season is kicking in i turned on my furnace to put heat in the house only to find that the igniter isnt glowing so i took it out and checked it and found that there was a crack in it so i went and got a new one installed it and kicked on my furnace only to find that the igniter still isnt working i took it back to where i got it they inspected the igniter and found no issues i have looked online but everything i found is useless its a new igniter so why would it be igniter issue if i google search "new igniter not glowing furnace not working". any help would be greatful thanks.
Old 10-13-18, 03:31 PM
Received 3,187 Likes on 2,862 Posts
Welcome to the forums.
We need to know what type.... like make and model.... of furnace you have.
Many furnaces have a control board in the lower blower section. There may be a small clear lens where you can look in and see a trouble code blinking.
If your furnace has a draft inducer blower.... it needs to be running and prove pressure before the igniter will heat.
Old 10-13-18, 05:27 PM
R
Do you have and know how to use a meter?
