The Heat Is On (sometimes...)
Luxaire
G8D10012UHB11a
After the furnace has been idle for several hours, there is a very good chance (~75%) it will not provide heat when the furnace places an order. What happens when it doesn’t work:
- the thermostat places the order
- the fan starts
- the surface ignitor begins to glow, then goes dark
- the fan continues
The remedy that works 100% of the time:
- turn off the switch on the outside of the furnace
- wait 30-60 seconds
- turn on switch
- furnace works fine until the next long idle period
Any ideas what the problem(s) might be?
G8D10012UHB11a
- the fan starts
- the fan continues
- turn on switch
There should be a small clear lens in the blower door. Look inside for a blinking LED.
Count the flashes for the trouble code. The codes are on the back of the blower door.
Remove the blower door. Look at the control board. In the bottom corner you will see the LED. The codes are right on that board. I think it should blink continuously with no call for heat. Opening the blower door lets a safety switch open to disconnect power. You can hold that in to observe operation. Once the switch is released.... the codes are erased.
I removed the blower door, and located the LED and the codes. The LED was not blinking.
I held in the safety switch, and the LED lit for about one second and stopped.
While continuing to hold in the safety switch, I called for heat. The operation failed to produce heat:
- the fan started
- the surface ignitor began to glow, then went dark
- the fan continues
Does this get us closer to a solution?
- the fan started
- the fan continues
