Gas Furnace - Replaced inducer blower... blower starts than shuts off
Hi, I have a problem with my inducer blower, my old inducer blower I had rusted up and part of it broke so I decides to replace it. After I replace the part, I start up the furnace.. the inducer blower starts then the entire unit, but then the indicer blower turns off but everything else is still running but no heat.
I think my furnace had locked out from failing so many times before. Any ideas? Idk where the reset switch is either.
Unit - 2ycc3030a1075aa Trane gas/electric
Welcome to the forums.
The only thing that's still running is the main blower.
There is no reset button. Turn the power off for 10 seconds and then back on.
There is little tech info available on this packaged unit.
This unit uses an intermittent ignition system. I'd imagine that hasn't been cleaned in a long time and may be the problem.
the inducer blower turns off but everything else is still running but no heat.
Turn off power breaker to the house or pull out central air fuse? Sorry I'm still just learning to do these things for myself.
last time someone came to my house and all he did was turn on the gas to the furnace and charged me $85
