Sporadic Ignition Sequence-Tempstar/ICP, (NTC5-100BJC)
Sporadic Ignition Sequence - Tempstar- ICP(NTC5-100BJC) Gas 80% Furnace with Honeywell SV-9501 smart gas valve
Observed sequences(s)
1) Call for heat
2) Induction fan comes on
3) Igniter glows red
4a)
If lucky: While the igniter is glowing red a small pilot flame appears near the igniter and ignites the gas burners, followed by the blower, and all is good, with heat until the call for heat stops and furnace shuts down.
4b)
If not so lucky: If no small pilot flame appears while igniter is glowing red, the Igniter will stop glowing red after a couple seconds, pause and several seconds later glow red once again. If no small pilot flame appears during second glowing red igniter, it will stop glowing red and terminate the sequence. At this point I "think" it locks down the process for a long period (except that the induction fan stays On) until power is turned off/on.
Sometimes will take several continuous hours to get started, sometimes on first try sometimes the nest program will start it on its own.
1) Call for heat
4a)
4b)
I'm a little confused. After the igniter heats up.... the main gas valve should open and you should get full burner ignition. Are you saying that the igniter only lights a pilot light ?
Gotcha..... a Smartvalve.
They can be a little tricky to diagnose. There is a diagnostic routine listed in the link below.
Smart Valve (pdf)
Smart Valve (pdf)
