Furnace Short Cycling
Old 11-26-18, 10:34 AM
A
Hello,
I have a Luxaire FL9M series furnace. Last season I replaced the blower motor after it burned out and added a humidifier. At the end of the season I noticed it was short cycling. Over the summer I increased the duck work from 4" to 6" runs on about half the house at the suggestion of my HVAC guy.
However, the furnace is still short cycling. I read off error codes for "Limit switch open" and "low flame sensor current". I replaced both the limit switch and the flame sensor. The furnace is still short cycling.
Any idea on what the culprit could be?
Also, I think the inducer motor sounds rather loud, however it runs.
Normally it takes 3-4 cycles for the furnace to kick on and stay one.
Old 11-26-18, 10:48 AM
R
Received 101 Votes on 95 Posts
Is the limit opening during a heating cycle?
The error codes aren’t indicating what parts to replace. They are indicating why the furnace isn’t operating. Further diagnosis is needed.
What’s the heat rise of the furnace?
The secondary heat exchanger or evaporator May be dirty and need cleaning. What air filter is being used?
Old 11-26-18, 01:53 PM
A
I am not sure how to tell this.
The error codes arenít indicating what parts to replace. They are indicating why the furnace isnít operating. Further diagnosis is needed.
Ah, well luckily the parts were relatively cheap
Whatís the heat rise of the furnace?
Do you mean the temperature difference across the furnace?
I am using a MERV-8 air filter
Old 11-26-18, 03:22 PM
R
You can look at the error or use your meter to tell if the limit is opening or not. Yes, temperature across the furnace. Take the air filter out and see if the problem continues.
Old 11-26-18, 04:05 PM
Received 1,029 Votes on 955 Posts
This is a pretty sophisticated modulating furnace.
Luxaire FL9M manual (pdf)
