Carrier furnace
Old 12-11-18, 02:32 PM
H
Carrier furnace
My thermostat controller is completely dead. I checked on the electrical that supply the furnace and is good. Opened up the furnace cover and found out the PCB board unit is CEPL 130438-01. I checked on the AC electrical input to the DC power converter input and no power. I replaced the PCB board and still dead. Is there anything else that may go wrong. Thanks
Old 12-11-18, 02:35 PM
Received 3,423 Upvotes on 3,069 Posts
Welcome to the forums.
That board doesn't run on 120vAC..... it only switches that voltage to the blowers and igniter.
The board runs on 24Vac. Look for a 120vAC to 24vAC transformer. That's what probably is defective.
Old 12-11-18, 03:04 PM
H
Yes it's. But I think the 120vAC that run to the DC converter come from the PCBoard and does not have the 120VAC to supply the converter. I assume there is another sensor to give signal a relay to power up the DC converter. thanks
Old 12-11-18, 03:08 PM
H
Maybe I need to check on the PCB itself (including the newly bought unit). How to test this board?
Old 12-12-18, 11:03 AM
H
The PCB is Ok, I tried it on another unit and it works.
Old 12-12-18, 01:32 PM
A
Received 83 Upvotes on 75 Posts
These boards run the 24vac from the transformer through a limit switch and flame rollout sensor. If either is tripped/broken then the board will act dead like you are seeing.
Old 12-12-18, 01:37 PM
H
Can you tell me which one is the limit switch and Flame rollout sensor ? Thanks
Old 12-12-18, 02:39 PM
H
I found the flame roll out sensor. checked and reset it and still dead.
Old 12-12-18, 02:56 PM
H
Are these two different sensors ?
Old 12-12-18, 06:00 PM
A
What is the model number of your furnace?
Follow the wires. Roll-out switch just above burners. Limit switch can be above or below but is to sense temp in air going through system. Sometimes in blower compartment.
Old 12-14-18, 07:39 AM
H
Carrier model: PG8JAA066110
Old 12-14-18, 08:24 AM
H
I found the limit switches as well . There are two limit swictches on the heat exchange and another one on the flue elbow. Including the Rollout swicth there are 4 sensors chain in a series connection.
Old 12-14-18, 12:36 PM
A
Diagram on page 32 - https://www.questargas.com/ForEmploy...G8M%20PG8J.pdf
First check for 24vac at both sides of the fuse. Then at each of the roll-out sensors and limit switches.
