No Call For Heat
Old 12-21-18, 09:43 AM
B
No Call For Heat
Hi All
Trane, model TUC060C936A0. Light is blinking slow, continuously which is showing “Normal, no call for heat.”
I had a smart thermostat installed over the summer and the AC works fine. I’m assuming the tech tested the heat but not sure. I contacted their support and after a few basic troubleshooting steps with wiring and settings, they are sending a replacement. Red wire goes to RC, no wire to RH.
If the thermostat is not at fault, what are the first few things I should check? Fan doesn’t come on but will if I switch it to “On”. Thermostat shows that it’s requesting heat. AC works fine. I checked the continuity on the hot ignition which read .6. I don’t hear anything come on or click whatsoever.
Thanks
Old 12-21-18, 11:47 AM
A
Received 83 Upvotes on 75 Posts
Try jumpering the red wire with the W1 (normally white) wire together to bypass the thermostat.
Old 12-21-18, 04:11 PM
vinniemak's Avatar
Hi, Bobby:
Just my 2 cents ; did you check the ignitor with an Ohm meter ; should read low resistance between 3 to 10 ohms...continuity is probably okay but if the resistance is higher may not complete the circuit back to board. I assume you have a HSI like a Q3400 or Q3450 ignitor ??
Also, I believe there should be a jumper in your thermostat that connects RC to RH thus only one wire is required to RC ; but not sure.
Finally I believe the W wire is for heat ; double check that.
Again the above are my 2 cents and hope they help you.
Old 12-21-18, 04:25 PM
Received 3,415 Upvotes on 3,063 Posts
On a call for heat..... the draft inducer blower comes on first.
If that it isn't happening.... don't worry about the igniter.
It's not going to be a blower problem as that's also used for A/C and that is ok.
Old 12-21-18, 05:27 PM
B
Thanks, guys. PJ, when you say the blower is not at fault, are you saying the draft inducer?
I will have a chance tomorrow to try and bypass the thermostat.
Thanks
Old 12-21-18, 08:13 PM
I use the proper names.... blower and draft inducer blower.
Your main blower is not causing your problem.
Old 12-21-18, 08:14 PM
B
Figured... just making sure.
Thanks
Old 12-22-18, 09:23 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, how long ago was the stat installed? Call the service co. and have them come back and check it out, don’t ASSUME anything.
Geo
Old 12-22-18, 02:23 PM
B
It’s the thermostat! Gas and electric company installed it over the summer. Called Ecobee support and they are sending a new one out.
Thanks for the help, all! Major relief that it wasn’t anything major.
