flame - no call for heat
my Amana 80 SSE blows cold air all the time, even set the thermostat at off. error code says "flame - no call for heat". if I turn the furnace power off, and then back on, the furnace worked fine once a day. the furnace will not be ignited until next day once it is off. I changed the air filters and checked several parts including thermostat, no problem was found. any help or suggestions? thanks
KH
KH
with power off, check resistance between the flame rod and the cabinet. multi-meter required.
if your meter shows open line, the circuit board is bad. if it reads a resistance, the flame sensor or wire is damaged and there's a path to ground.
I have bought and changed the flame sensor. I also changed thermostat with one that was known working. it can be ignited once a day. when I tried within hours after it was off, the ignitor would glow for a few seconds, but would be off before igniting.
If the flame sensor is good and not shorted..... the control board is bad.
Nothing else will cause that error.
Every control is different. Most start the blower 30-60 seconds after the burner lights. I'd rather it start earlier than later. If you post the part number of the control board I could check the details.
Heat delay to blower on is selectable: 30 - 45 seconds
Heat delay to blower off is selectable: 60 - 90 -120 - 180 seconds
