no heat/thermostat error 089
Old 01-20-19, 08:45 AM
system is 8 years old.
No issues until today
Thermostat reads err 089
manual indicates 'heating/cooling equipment missing'
honeywell visionPRO IAQ/ lennox furnace (in attic, I have not climbed up to check for error lights)
Room temp is below set temp, so looks like it is not working.
I turned heat OFF at tstat, then back on, with no result
Turning breaker off/on also does not solve
Old 01-20-19, 01:37 PM
Received 479 Votes on 449 Posts
That code would indicate a problem on the W wire that turns the furnace on. You could try shorting from R to W at the furnace and see if you get heat.
If not..... you may have a safety limit switch open. Quite possibly a flame rollout switch has tripped.
Old 01-21-19, 08:35 AM
Had a tech come out, he tested everything and found the thermostat non functional.
New thermostat solved this problem.
