G20 whisper heat no pilot light
Received 0 Votes
1. In which area you live and ambient temperatures you usually experience.
Northwest PA temperature typically varies from 19°F to 80°F and is rarely below 3°F or above 87°F
2. House style and construction details.
2 story home with walk in basement and attic as well, heater is in the basement
3. Make, model and age of equipment related to the problem.
unsure of the age but the heater is a lennox whisper heat g20
4. Fuel type.
natural gas
5. Water temperature and pressures of boiler systems.
dont think i have one
6. What type of zoning do you have with your boiler system.
7. Thermostat type.
basic honeywell slide on the top for temperature selection
7. Anything else that would be useful. No detail is to small.
i have a lennox whisper heat g20 with the damper door switch bypassed,
the pilot doesnt light
the honeywell s8670k ignition controle module would blink 2 times for retry but now the led arent coming on
i had tried taking the thermostat off the wall and jumping red to white and the blower came on but no fire
thank you
4. Fuel type.
natural gas
7. Thermostat type.
thank you
