Replacement Inducer Goodman 0171M00001S question
Old 02-05-19, 05:31 PM
G
I suspect I have a bad inducer motor so I ordered an OEM replacement and went to replace it today but noticed that the new OEM directly replacement is missing the drain plug on the bottom of the inducer. We called repair clinic and they inform that the manufacture made a change and this is indeed the correct part. Has anyone ever ran into this? Why would they get rid of the drain on the inducer? I have a propane furnace.
What would happen if I installed this new motor and it doesn't have a drain like the old one?
Old 02-05-19, 06:37 PM
Received 1,203 Votes on 1,113 Posts
Does your furnace have a drain line connected to the old inducer ?
Old 02-05-19, 06:45 PM
G
Yes it does.
I've done some additional research and I think what I need to do is this. Purchase a new elbow that has a drain built in and then run that to my P trap where my old inducers drain went. You agree?
I wonder why Goodman got rid of the drain on their inducer.
Old 02-05-19, 07:08 PM
Sounds like a likely repair. I'd need the full furnace model number to comment further.
Old 02-05-19, 07:13 PM
G
the model is = GMS90703BXA
Old 02-05-19, 07:22 PM
0171M00000S is the inducer listed for that furnace. It has the drain fitting.
http://goodmanrepairparts.com/ventin...-goodmanamana/
Old 02-05-19, 07:25 PM
G
We ordered it from repair clinic and it doesn't have the fitting. We called them and they informed that goodman changed the part and no longer manufacture it with the drain.
I have noticed on some websites it shows the fitting but I'm guessing they just haven't changed the picture yet.
We did indeed order that part number BTW
https://www.repairclinic.com/PartDet...00001S/3342922
Old 02-05-19, 07:34 PM
Is your furnace set up for upflow (burners at the top) or counterflow(burners at the bottom) ?
I thought the yellow plug was a drain connection. It looks more like the pressure switch port.
Old 02-05-19, 07:37 PM
G
The furnace lays horizontal. I've attached a picture.
Old 02-05-19, 07:39 PM
On that link page I left to the Goodman site is listed this part....
Horizontal Vent Drain Kit RF000142 | Goodman Repair Parts
Old 02-05-19, 07:40 PM
G
My plan is to order this new elbow
https://rdt.prod.repairclinic.com/Pa...71802S/2645593
and run longer drain line replacing the one in the picture above with the green clips.
Old 02-05-19, 07:45 PM
Is your picture of your furnace upside down ? It looks like you already have that drain fitting.
Old 02-05-19, 07:49 PM
G
No, the picture is just as it lays on the ground.
I don't have the drain fitting on the side as the one in the link does. I think I can get away with installing that new elbow in the link as long as that will force all water out the side drain.
The current elbow has what appears to be a drain at the top but it's currently sealed and there is no way for me to position it to get water to flow in that direction. I hope that makes sense.
Old 02-05-19, 08:01 PM
Here's the problem..... water goes to the lowest point. So it's not going to go up into the exhaust line.
Where do you plan to install the right angle fitting ?
The white fitting that is on the inducer now is for when the furnace is standing up. Then you don't need the inducer with the drain port.
Old 02-05-19, 08:08 PM
G
The new right angle fitting that I'm going to purchase (with the drain on the side) is going to replace the current right angle fitting you see in my current furnace. I was hoping that the condensation is made in the exhaust pipe and would drain via this fitting.
Take a look at my furnace again and notice there there will still be another drain a the lowest point connected to the box behind the inducer. Where is all of the condensation produced? You still see an issue with my plan?
I'm still puzzled why Goodman would of removed this drain fitting on their "new and improved" inducers.
I saw the horizontal vent drain kit that you posted but I don't quite understand where this would be installed.
Old 02-05-19, 08:28 PM
I couldn't find any installed pictures of it but it goes in between the inducer and the right angle fitting going up. My guess it goes right at the inducer..... in the gray pipe.
Old 02-05-19, 08:30 PM
G
Since it goes there, do you see any difference in my plan with the new elbow?
BTW, thanks for all your input!
Old 02-05-19, 08:52 PM
G
Here is a picture of my plan.
Old 02-05-19, 10:35 PM
I'm guessing it's worth a shot.
Old 02-13-19, 02:34 PM
G
UPDATE
New inducer and new elbow installed and it's been running now for about a week straight with no issues. I've attached a picture for you to look over and see what I did. I guess the overall issue was that the inducer couldn't always keep up the proper RPM to keep the pressure switches engaged. I guess time will tell if that was really the issue or not.
AGain thanks for all the input.
This forum rocks!
  #21
Old 02-13-19, 04:42 PM
Good job. Nice and clean. Thanks for letting us know how you made out.
  #22
Old 02-13-19, 04:48 PM
G
Thanks!
I'll tell you one thing. It sure is A LOT quieter and sure does seem to produce A LOT more condensation!
