Proper setup using ecobee 3 on a 2 stage furnace
Old 02-06-19, 03:50 AM
A
I had a new Amana AMEC960803bnac natural gas furnace/ac installed last week along with the ecobee thermostat. The installer has the 2 stage controlled automatically in the furnace according to the dip switches and tstat, isnít this something that should be controlled in the ecobee ?
Old 02-06-19, 02:00 PM
user 10's Avatar
Received 45 Votes on 39 Posts
Yes it should be controlled by the stat to take full advantage of the furnace.
A wire is required from terminal W2 on board to W2 on the stat.
There's a dip switch setting to turn off timed staging on the board. The stat has to be set up for 2-stage.
Old 02-06-19, 02:23 PM
A
That was my thought, thanks!
