LP Furnace flame flutters off and on and doesn't always light
Old 02-09-19, 04:49 AM
W
https://youtu.be/h31cvhVHQ1E
https://youtu.be/yy9vCIG04rc
90% effec furnace just replaced rusted out inshots It is usually the middle 2 that flutter, never seen the outside ones do it.
Old 02-09-19, 04:59 AM
B
Received 93 Votes on 81 Posts
The furnace should have a combustion air control per burner tube. Try adjusting the middle ones to eliminate yellow/orange tips on the flame. They should be blue.
Old 02-09-19, 06:05 AM
W
There are no adjustments That would be too easy lol
Old 02-09-19, 06:08 AM
W
I just had the furnace serviced with the old inshots. Without taking a micrometer to measure the new burners with the old, they compared side by side to be equivalent
Old 02-09-19, 06:19 AM
W
old inshots
New ones in furnace may have to remove burner box again and take pic of them
Old 02-09-19, 07:37 AM
R
Received 106 Votes on 100 Posts
What is gas pressure?
The nozzles could be clogged as well.
Old 02-09-19, 10:20 AM
Received 1,204 Votes on 1,114 Posts
That's not an air or burner issue.
It's either low propane pressure or more likely clogged orifices. When you take the burner out..... there is a little tiny hole where the propane enters the burner. Propane has more "junk" in the fuel and clog up orifices faster than with natural gas. I'd clean all of them.
Old 02-09-19, 04:20 PM
W
Thank you for the replies. It has been stupid cold the last week and I'm down to less than 20% in tan
Don't remember which one that one was. I wondered about gas pressure
Old 02-09-19, 06:03 PM
With under 20% liquid you're not getting a whole lot of vaporization on a cold day.
I'm sure your pressure is low. Clean all of them while you're in there.
