FASCO 70582338 inducer for Goodman
Old 02-16-19, 07:06 PM
I want to replace my furnace inducer, because the motor starts very slowly and makes more noise than it should, as it is around 12 years old. The new one has 2 wires instead of three, AND the pressure switch high temp tubing is mounted below the original style.
Question 1: what is that 3rd wire for and how do I 'make one' for it?
Question 2: If I replace the tubing with longer to make it reach, will it have an ill affect on the pressure switch?
I do it myself, thinking plug and play. missing wire throws me for a loop.
Thanks for any and all help ;-)
Old 02-16-19, 08:19 PM
Received 1,189 Votes on 1,100 Posts
Welcome to the forums.
I'm guessing this is a packaged unit as the new inducer is 240v.
No model number so if I have to guess again...... the old inducer may be a 120/240v model.
The pressure switch location shouldn't be a problem.
You can replace the tubing with high rubber or silicone tubing.
Old 02-24-19, 06:31 PM
Thanks for the reply. The inducer model # is in the title. The Furnace model # is APG12300701A 208/230 Volts.
Essentially, they are identical, except that black wire is on my old inducer, not the new one...
What is the black wire for?
Old 02-24-19, 07:15 PM
From the Goodman manual......
Goodman APG packaged unit manual (pdf)
Old 02-24-19, 07:57 PM
Ah! So if it's supposed to be 230V, I don't need the black lead anyway. The original unit's black lead is glues to the body of the furnace...
Is 208V operation unusual? Just wondering...
Old 02-24-19, 08:24 PM
208v would be found at a commercial site with three phase power.
That inducer was designed to work in many applications.
