Furnace not turning on
Received 0 Votes
In the past few days I have two separate instances where our natural gas furnace didn't turn on even though the thermostat said it should. Both times I manually turned the furnace off and then back on (light switch connected to the furnace) and it started right up. Any ideas on what might be the issue?
Take the burner service door off. The ID plate is on the side wall near the burner.
Post the full model number...... not just the group.
