blower fan stuck on
Old 04-21-19, 04:29 PM
W
blower fan stuck on
First post, looking for some help. I know another "blower fan stuck on" post, sorry!
Problem: Armstrong air unit, 15 years old. Blower fan was replaced probably 8 years ago. The main blower fan remains on, even with thermostat wires completely removed at main controller board in furnace. When I turn the main power switch on to the HVAC unit (with thermostat wires undone), the fan exhaust blower and main blower fan run, and stay running.
Things I've tried: I've removed all thermostat wires from the main control board to eliminate thermostat. I then bought a new Honeywell ST9120U1011 universal fan timer. Hooked everything up, excluding the thermostat wires; applied power to the HVAC, and same thing happened: both the exhaust fan and main fan turn on.
Some photos (old board, new honeywell, side pic of the fan (capacitor?):
I read a lot about a fan relay switch getting stuck, but I cannot find one anywhere. Any ideas?
Old 04-21-19, 09:57 PM
Received 1,595 Votes on 1,470 Posts
Welcome to the forums.
That should be a clue right there. You are talking about two different blowers. One stuck relay would not keep two blowers on. Your problem is a furnace board needs to be completely installed and wired correctly. Any open limit switch will keep both blowers running as an indication of a fault.
If the control board has a fault light on it...... it should be flashing a code.
Old 04-22-19, 05:49 AM
W
Thanks for the response!
Both the old controller board and the brand new Honeywell controller board act exactly the same when completely wired up. I do not see any fault codes blinking.
Is there a separate furnace board I should be investigating?
Old 04-22-19, 01:44 PM
Is the LED blinking anything ?
Check for 24vAC between R and C..... is it there ?
Old 04-29-19, 12:34 PM
W
Main control board flashes a green light heartbeat. There's a green light that flashes up near the gas lines, 4 times.
Assuming I'm using my multimeter correctly, I'm only reading ~300mV across those two lines, at the main control board.
Old 04-29-19, 02:41 PM
Four flashes near the gas valve ? Is it right on the valve ?
I think the model number of the furnace is going to be needed.
There is a pair of yellow wires that connects to the board near the fuse. Check them for 24vAC.
I'd imagine you'll find that present which points us to an open limit switch.
Old 04-30-19, 07:59 PM
W
Thanks for the feedback everyone. I gave up and called in a professional. It was some sort of temperature sensing valve (~$18). It was telling the system that the temperature was hot and the fans needed to run to cool the system down before shutting off.
