Smoke from residential chimney at 85 degrees...Why?
Old 05-26-19, 02:56 PM
I live in a tall building in New York City (over 150 apartments) and there's another one a block away. Both buildings have black smoke coming from the chimney even when the temperature is in the 80s. The buildings are co-ops each with a Board of Directors that supposedly care about costs. both buildings use oil heat. I don't feel any steam from the radiators. What's going on?
(Just realized it must be gas ranges, but does the black smoke comply to the law? I think it's too black.)
Old 05-26-19, 03:20 PM
Upvotes Received: 12
A gas range's combustion products are room-vented, and they do not produce visible smoke under normal operating conditions.
Do you have individual water heaters for domestic water (showers etc) in the apartments, or is there a central hot water system that's oil fired?
Old 05-26-19, 03:25 PM
Upvotes Received: 141
Does your building heat it's own water or does it use steam from Con Ed to produce hot water?
Old 05-26-19, 03:36 PM
Yeah, I think the boiler heats the water. They shut off the water when they're cleaning the boiler.
Old 05-26-19, 04:04 PM
Upvotes Received: 26
That’s oil smoke. There’s a problem with the boiler.
user 10 voted this post as helpful.
