A/C will not shut off after set temp is reached
Old 05-29-01, 03:59 PM
Guest
Question
My A/C will not shut off after reaching set temp. I recntly changed the thermostat thinking it was the problem,
but that didn't work, the A/C keeps running after the set temp has been reached. I hope you can give me some type of
idea of what's wrong with the unit. The unit is a Bryant
model# 517en024075. The unit has a mercury thermostat, which is level. In order to shut the unit off the thermostat temp has to be increased.
[Edited by IHAWL on 05-29-01 at 07:22]
Old 05-29-01, 04:51 PM
HVAC Man
so how do you get it to turn off? raise the temp some more?
is it a mercury T-stat? if so, It needs to be level. or it may be a relay, or outdoor Condenser sticking, can't tell at this point
