inducer motor
Old 09-30-19, 02:08 PM
R
inducer motor
inducer motor going on for a minute then off. i am only running the A/C so should not be on. has never done this before. furnace is Goodman GMPN100-4 and about 18 years old. have not used it for heat very much as i burn wood
Old 09-30-19, 02:30 PM
Received 4,047 Upvotes on 3,631 Posts
Welcome to the forums.
That sounds like an issue typically caused by wifi thermostats..... in particularly the nest.
Only the thermostat can turn the inducer blower on.
Old 09-30-19, 05:24 PM
R
Received 199 Upvotes on 181 Posts
Are you using a Nest thermostat?
Not to get off topic but the Goodman GMP model has known heat exchanger problems. Make sure the unit is looked through before heating season.
