G51MP-36C-090-1 Lennox Gas
Old 10-08-19, 09:46 AM
Z
sometimes the igniter will heat up but the burner will not ignite. Repair man says it's my control board that is bad.
Old 10-08-19, 11:25 AM
user 10's Avatar
Received 57 Upvotes on 50 Posts
you have to see if the gas valve is getting power after the igniter warmup period.
Old 10-08-19, 12:05 PM
Received 4,049 Upvotes on 3,632 Posts
Welcome to the forums.
There is a 12 pin plug on that board. Those plugs/receptacles get corroded with age. Sometimes just unplugging it a few times is all that's needed. You could spray just the plug with a small bit of contact cleaner or WD40. Plug-unplug it a few times.
The same problem can also happen on the gas valve if it uses that similar white plug.
Same repair for that end.
