Goodman heating furnace
I have a Goodman heating system and today I want to use it for the first time in the season and I notice it not working there is a countious light blinking I checked and fixed all the wiring then it's start blinking a 3 times flash code I changes the pressure switch then it's start blinking a 1 time error code and the ignitor don't even light not
can anybody pls help me
Not quite sure what you're doing there.
The pressure switch needs to prove (short) before the igniter will start heating.
You need to use a meter to see if the pressure switch is closing when running.
Posting the model number of the furnace is helpful too,
