York diamond 90 gas furnace: code 11
Old 10-22-19, 01:13 PM
I have a York diamond 90 gas furnace that wont ignite. I have a code 11 which is broken rollout wire. I cant bypass since both wires go into the control board{plug-in}. would this cause yhe ignitor not to heat up and/or is the control board defective. I put a new tested ignitor in
Old 10-22-19, 06:34 PM
Received 374 Votes on 351 Posts
Welcome to the forums.
Yes..... the rollout sensor wires go to the multi pin connection on the control board.
No.... you cannot bypass that sensor due to safety concerns.
You should be able to check the switches for a problem.
I'd need the full model number of the furnace to comment further.
Old 10-22-19, 08:14 PM
hi pete! The model number for furnace is P3URB10N05501D. I changed the flame roll-out switch too.
Old 10-23-19, 07:06 PM
just wanted to say that the inducer and blower motor come on but that's it. I don't know if that code would prevent the ignitor from heating up.
Old 10-23-19, 07:21 PM
The main blower is most likely a timed function.
If ANY safety switch is open...... the draft inducer will not start. Since the draft inducer is running.... that points to the pressure switch not proving on vacuum.
Old 10-23-19, 07:23 PM
would that give me the code for a broken rollout wire?
Old 10-23-19, 07:27 PM
I"ll have to look and see how to test the pressure switch
Old 10-23-19, 07:38 PM
Are you still getting the fault code 11 ?
The rollout switch wires should be brown to pin 11 and black to pin 5. Is that correct ?
Measuring from pin 5 to pin 11 should be 0v.
Measuring from pin 5 or pin 11 to ground should be 24vAC.
Manual
Old 10-25-19, 01:53 PM
yes but I really haven't done anything yet. I checked the new ignitor and im only reading 7 ohms. im not familiar with a multimeter, so I don't know if im doing it right. tried the pins but it only moves the needle on ohms. guess ill have to call someone. I still have the same code 11. I don't know how to check pressure switch either.
Old 10-25-19, 05:32 PM
Received 36 Votes on 33 Posts
Post a picture of the broken wire.
A broken wire still opens the circuit. And will cause the unit to shut down.
What happened to the old ignitor to require changing it?
Old 10-25-19, 05:45 PM
user 10's Avatar
Received 35 Votes on 30 Posts
You can bypass it with the gas off to see if the inducer comes on and igniter glows.
normally a open rollout indicates the heat exchanger is bad - you have to verify it's actually open.
Old 10-25-19, 07:13 PM
good evening gentlemen! the inducer and blower both come on. the unit will run for a few minutes and shut down because the ignitor will not heat up. The code I get is code 11, broken rollout switch wire, but the wires themselves look fine. I replaced the ignitor because that's usually the most common problem, at least I thought it was. I checked both fuses and have continuity but i'm not familiar with a meter so I have no idea where to set it to check ignitor, pressure switch,and rollout pins. I set the meter to x10 on ohms and only got a reading of 7 on the ignitor.. Being brand new, I must be doing it wrong.
Old 10-25-19, 07:42 PM
user 10's Avatar
sounds like a bad connection.
