Furnace off / resets with fan switch off then on
Old 10-31-19, 08:03 AM
B
Trane XE80 natural gas furnace shuts off even though thermostat is calling for heat. If I turn the fan switch off then on the furnace will work as normal for a while but then turn off again. Checked the filter and it is good. Any help would be appreciated.
Last edited by bwilker; 10-31-19 at 08:12 AM. Reason: To thank forum for their expertise.
Old 10-31-19, 09:54 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, when the blower is running do you have a good flow of air coming out of the registers?
Are there any error codes flashing?
Geo
Old 10-31-19, 10:47 AM
B
There is a good flow of air. The LED that flashes is located inside with no hole to see it. When I take the panel off the door switch turns off the power so the LED isn't blinking. I just took the panel off because it stopped again and pushed the door switch by hand and the furnace is working again. Next time it shuts off I'm going to do a continuity check on all the switches. Thank you for your reply and if you have any other suggestions it sure is appreciated,
