Bryant Plus 90 Error codes
Can anyone tell me where that I can find a complete list of error codes for the above listed furnace?
Bryant 80 plus information
Have owned our Bryant 80 plus furnace for over ten years. Recurring problem with the flame sensor. Cheap and easy enough to change. ( cleaning the sensor works OK but does not last). The hot surface ignitor failed and was also easy to test (continuity tester) and replace. Finally the furnace began to function erratically with confusing error codes. Hired a licenced HVAC contractor. It appears that a number of these units had faulty control panels I guess you could call them a (mother board). Installed new $350.00. I hear that Trane has purchased Bryant, not sure if that makes a difference.
