hot air only flows one side ( upstairs)
Old 11-26-19, 02:21 PM
W
Weather King Oil furness. Furness in garage that is suppose to heat downstairs and upstairs of house. All the hot air output seems to go to the upstairs circular aluminum pipes and very little goes to the other side which feeds the entire downstairs
Old 11-26-19, 03:09 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
Many times when the heat and the A/C share common ducts..... dampers are installed to direct the flow of air. It sounds like you may possibly have a damper that is set more towards upstairs. Check the supply duct work and see if you can locate any handles coming out of the side.
