Furnace manual?
Old 12-01-19, 06:02 PM
R
Furnace manual?
I just bought this house. It has a RUDD Silhouette II furnace. Am looking for a manual to it. NOT one single manual to anything in this house. Could you guide me to one.
Old 12-01-19, 07:30 PM
R
Received 185 Upvotes on 169 Posts
What’s the model number for the furnace? There are online manuals available.
What specifically are you looking for in the manual? Most gas furnaces operate in the same manner and no manual is needed for troubleshooting. The wiring schematic and code chart should be in the furnace on the inside of the door.
Old 12-02-19, 04:28 AM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
For almost any of your appliances, you can go online and down load most manuals.
Old 12-03-19, 10:26 AM
R
furnace manuals
But you have to find the model and serial numbers. Too bad these companies can not put them along with the model name right on the front where they can easily be seen.
Old 12-03-19, 10:29 AM
Norm201's Avatar
It will usually be located behind an access door or on the back side.
Nobody wants to see model number on their appliances. brand name OK, but not model numbers.
Old 12-03-19, 09:40 PM
Received 3,423 Upvotes on 3,069 Posts
The ID tag on a gas furnace is always in the same exact place. It's inside on the side wall near the burner. Remove the front burner service cover and it should be extremely visible.
