I need the main control gas valve. for ...
Old 12-05-19, 10:31 PM
B
1985 MAGIC CHEF LP GAS FURNACE ... model # G6A750-11 SER.# A-15283E AB ? 75,000 BTU Can u help me ?
Old 12-06-19, 07:41 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
Is that a standing pilot furnace ?
It's borderline worth putting in a new gas valve on a furnace that old.
Hope you've had the furnace serviced.
Especially the heat exchanger inspected and cleaned even more so with propane use.
Are there valves available..... yes.... but they are universal type valves and will need to have their gas pressures set. I wouldn't call that a DIY job.
What is the problem with the old valve ?
