heater won't stay on
Old 01-14-20, 09:55 PM
Carrier Super Saver -model# 58SSB
unite ignites and I see ll the lames but blower won't start so furnace shots off after about 30 sec. I tried running the fan on thermostat and it won't work either- everyone talking about reset switch but I can't find the darn thing , if there is such a thing it should be easily visible- any suggestion?
Old 01-14-20, 11:26 PM
Received 3,415 Upvotes on 3,063 Posts
Welcome to the forums.
There is no reset switch for the blower. If your blower won't work with the heat or in the FAN ON mode then the motor is most likely bad. The blower is timer controlled from the board in heat mode.
We usually confirm with a voltmeter the voltage going to the motor.
