Goodman Gas Furnace GMP075 3 Blinking lights no suction from the inducer motor
So, the fan works, but no flame, 3 blinking lights for "vent or pressure switch vent blockage"
I've seen a couple of related messages for the similar situation and I followed instructions and it looks like inducer motor nipple is blocked. If I suck air from the pressure switch, the flame turns on. If I try to suck or blow air into the nipple, it is completely blocked.
I've seen recommendations to use a small drill bit and somewhere is says paper clip, but could not find complete instructions. I can insert paper clip approximately 1 and 1/16 and then gets stuck, while the visible nipple length is approximately 3/4 of an inch. Is it deep enough? I can drill with 1/16 drill bit approx 3/4 of an inch. Not sure what is the right drill diameter and how long each of bit and clip can go to avoid damage.
Also, since this is completely blocked nipple, does it sound safe, until the issues is addressed, to manually shorten the switch connectors at the right time just to warm the house time to time?
Top Answer
02-17-20, 08:00 PM
https://www.homedepot.com/p/Lincoln-...H575/100341101
In the summer I use these for their designed purpose on AC installs. In the winter I use them to clean out plugged inducer ports.
I've never had a port completely blocked off where nothing would go thru. You should be able to push something small enough into the port to hit the fan blades. I use a sharp pointed probe to clean the hole. 1/16" may be too big.
Unfortunately shorting the leads on the pressure switch won't work. The furnace checks for those leads to be open on a call for heat and then go shorted when the inducer starts. If they are shorted from the start you'll get a shorted or closed switch fault code.
Thank you, will try something smaller and will try deeper.
I can start it "at the right time", after the fan starts, it gives me heating at least time to time when I can shorten it. But hopefully will be able to address the issue soon.
