Old siegler gas heater
Old 04-05-20, 05:13 PM
Whatís up I just moved into a new apartment about 2 days ago and we have an old natural gas heater... Siegler model # 775 UB -2-S.... when we first moved in the property owner told me that the heater worked but was very loud and that he was going to have it fixed ASAP; Iím a certified General Motors technician and I like to consider myself pretty handy so I figured Iíd look into it myself; the heater would work fine and blow hot air but was very very noisey and would shake pretty bad; the first thing I did was removed the back panel including the blower motor and fan assembly and found that there was probably thirty five years worth of dust and crap built up everywhere including on the fan; I took apart the fan and motor assembly and I cleaned everything to the point that I was satisfied and put it back together; when reassembled the shaking stopped so Iím assuming that there was so much buildup on the fan that it was just very unbalanced but I still had a bad rattle noise; I removed the front grill and glass panels and replaced the rope gasket and installed new hardware to make sure that the glass was tight and also cleaned out the front and anything that I could reach; when I put it back together it worked perfectly and was quiet and smooth as probably the day it was manufactured; however when it is on for a while I get an intermittent rattle from somewhere in the front of the unit; I have verified that it is not the glass or anything on that front grill; Iíve been trying to find a manual for this thing and canít anywhere; any help would be greatly appreciated
Old 04-06-20, 11:05 AM
Received 835 Votes on 782 Posts
Welcome to the forums.
That sounds like an old wall heater. There was very little info available online for them.
Old 04-06-20, 05:02 PM
The way that this is set up as far as I know is in correct; there is a knob on I believe the gas valve that when turned will start the heater but the motor literally just has a cord that plugs into an outlet; once
plugged in blower will run continuously regardless of temp and heat will stay on high; itís a headache ; would you know the correct operation of this unit and what would I have to do to correct this; I was trying to think outside the box seeing how I canít find a manual or any parts for this model and wondering if I could take the feed wire that plugs into the wall and run the wire into a box and install a dimmer switch so atlesst I could control the fan speed; any thoughts are helpful
Old 04-06-20, 05:05 PM
[img]blob:https://www.doityourself.com/4d774eb3-1be3-4dc4-968e-f0f88a919b9f[/img]
[img]blob:https://www.doityourself.com/ab2fffb8-ca49-4358-a555-8f24066e8b31[/img]
