Slight Adjustment of Furnace Flue and Makeup Air
Please see the attached pictures below, I am getting ready to do a basement remodel and I would like to frame out my duct work for the HVAC as close to the ducts as possible. However, what I believe to be the makeup air and Flue for the furnace, hang down quite a bit. What I am curious about is can I move the PVC to be along side the ducts vs underneath them as it is currently? I would imagine it would probably need 2 more 45 degree elbows to per pipe. I could not find anything specific about it in the documentation left behind by the previous owner.
Model: Trane XC 95
4TXCC008CC3HCAA
Any thoughts or suggestions would be appreciated.
Regards,
Adam
Model: Trane XC 95
4TXCC008CC3HCAA
Regards,
Adam
Thread moved to the furnace forum.
Post the full model number for the furnace.
The ID tag will be inside on the side wall near the burner.
The 4TXC model number is just for the cold coil.
XC-95 is the group.
You need to remove the burner access door and locate the ID tag on the sidewall near the burner.
XC-95 is the group.
My apologies this is the system I know the least about in my house.
I believe the correct model number is TUH3C100ACV4VAA. I will update the main post. Thank you for your patience
**Edit** looks like I missed the window to edit the original all model info now combined in this post.
Model: Trane XC 95
Cold Coil: 4TXCC008CC3HCAA
Furnace: TUH3C100ACV4VAA
Regards,
Adam
Model: Trane XC 95
Regards,
Adam
See if the manual in the link below is for your furnace. Your exact model is not listed.
You could double check your model number too.
The install section goes over the vent lines pretty well.
Trane manual
Trane manual
