Miller furnace help!!
I recently moved into a new house and there is a furnace in the garage I want to get running. I did all the normal maintenance and started it. It ran great until the blower kicked on and the black smoke billowed everywhere. So I too it apart and it was filled with rust and soot. Upon inspection after quite a while of vacuuming I found rusted out panels in the very back of the firebox. Is it possible for those to be replaced or am I better off to find a different furnace?
Unless that portion can be replaced so it's safe to use I'd be replacing it. We have a vented gas wall furnace we like because it can warm my back when backed up to nearly as well as the old wood stove.
