Unit Turns on, but Turns off While Still Calling for Heat
Old 12-08-20, 11:00 AM
D
Coleman: DGAA056BDTA
I made a post almost a year ago about this issue, but now I have much better detail about the symptoms (we live in the south, so by the time I got around to digging deep into the issue, we were in AC mode).
Unit does pre-purge(?), I hear a click, the igniter glows, another click, flames, blower starts less than a second later, immediately another click, flame goes out, unit remains on blowing air, 15 seconds another click, igniter glows, click, flames, click, flame goes out, 15 seconds, repeat.
It goes through the click, light, flame, click, no flame cycle five times. This entire time, the status light is solid and the unit is blowing fan-only air. After the 5th time the status light gives the one flash status code (Ignition Failure) and the unit turns off completely after about 30 seconds.
If I turn off the thermostat or lower the temperature to where it no longer calls for heat (it was still calling for heat), the status light goes solid again. If it turn it back on to heat or raise the temperature to call for heat, this process starts all over again OR if I do nothing and wait about an hour or so, it tries this process again. I don't think the site allows me to post a vid of what I see through the circular viewfinder.
Before I call in the repair guys...flame sensor? It's a much older unit where three wires goes into burner assembly (two white - HSI, one yellow - FS).
Side note: The AC portion of this unit works flawlessly.
Thanks!
Old 12-08-20, 02:03 PM
user 10's Avatar
Received 50 Upvotes on 44 Posts
Set the thermostat to off, open the unit and jumper R and W to rule out t-stat and wiring.
Mobile home furnace. https://www.questargas.com/ForEmploy...-DGPA-DGPH.pdf
Old 12-09-20, 12:07 PM
Received 3,410 Upvotes on 3,059 Posts
After testing for thermostat issue..... clean the flame sense rod. It's a piece of stainless steel rod.
Take it out and polish it good with a green Scotchbrite pad. No need to replace it.
Old 12-18-20, 03:09 PM
D
Thanks for the responses!
Is there any guidance on how to get to and clean the flame sensor based on this setup? According to the wiring diagram, the yellow wire is the flame sensor. It would appear that I'd have to disconnect the gas line and remove the entire assembly to get to it (the three wires go back to the circuit board via spade(?) connectors).
Thanks!
Old 12-18-20, 04:38 PM
Yes..... you may have to remove the entire burner assembly to clean the flame rod.
The Coleman units weren't known for ease of serviceability.
Old 12-19-20, 05:57 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Deeeeeeeeeeeeeeeeeeleeeeeeeeete
Old 01-12-21, 06:56 AM
D
UPDATE:
I removed and cleaned the flame sensor (had to Google how to replace the hot surface igniter to see how to get to the FS). It worked fine for about three days then the issue started again. To my embarrassment, when I went to clean it a second time - this time using fine sandpaper instead of a scotch pad, I damaged the assembly.
$160 later, I replaced the entire burner assembly which included the HSI and the flame sensor. Been almost two weeks with no further issues. Thanks!!
