Cool air
Cool air
Coleman evcon dgat075bdd furnace wasn’t heating trailer I took off the front panel so air can blow out the front and put a blanket in floor duct to block it off and now heats the trailer
Cool air
Yes it is heating my trailer with duct blocked off and face open. If I don't block duct work the furnace kicks on blows heat out the bottom for a split second then goes to very cool air. When I block duct work in floor it goes back to hot
Cool air
Guy come checked furnace said something came apart underneath and was drawing cold air from somewhere. All underneath has been checked and new insulation on everything and sealed up with plastic and will be insulation board as soon as I can get this figured out
Take a few pictures of the furnace and the duct work including the duct work under the trailer. Show where you block the existing duct to get heat. Need more information since none of us is there to see what is wrong.
