TT configuring Honeywell R7284
Old 01-18-21, 09:19 AM
G
Do I select YES or No when programming the "TT CONFIGURED ON" option when the 2 TT terminals are jumped with a wire?
Old 01-18-21, 10:05 AM
Grady's Avatar
Received 32 Votes on 30 Posts
You don't need to jumper T-T if the control is set to "NO". By setting the control to NO, the T-T terminals are ignored and jumpered internally. Is this control used on a boiler or warm air furnace?
Old 01-18-21, 11:22 AM
G
Thank you for your quick response. It is a Slant Fin boiler. What would happen if I used the jumper and said "NO" to the TT configuration? Thank you.
Old 01-18-21, 11:28 AM
Grady's Avatar
I don't think any harm would be done since the internal "jumper" is being used. BUT I couldn't swear to that. Am I correct in presuming you are replacing an R8184 which had T-T jumped with the R7284?
Old 01-18-21, 05:31 PM
G
I replaced a R7184B with the R7284U. No one wants to work on fuel oil boilers where I live. So I'm becoming a doityourselfer.
Old 01-18-21, 06:37 PM
Grady's Avatar
It's getting the same around here too. Slant Fin heat exchangers are a bear to clean properly, or at least were when I worked on them.
