Nordyne kg6rc won't ignite-steady red light
Old 01-18-21, 11:55 AM
Received 1 Upvote on 1 Post
Nordyne kg6rc. Furnace stopped working this morning. The red light is steady. At one point the light was flashing. But I shut it off and restarted it and now to light is steady. The inducer motor is running and after a while there is a click sound which repeats after a few minutes.
Please help. It cold up here in michigan.
Old 01-18-21, 06:21 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
A steady red light simply means the furnace is getting power. The click is probably the ignitor. You should see a glow in the burner area.
Old 01-18-21, 06:42 PM
Received 3,417 Upvotes on 3,064 Posts
Need the complete model number that is posted inside on the side wall near the burner.
That furnace has a red and green LED.... doesn't it ?
