Heat does not come on
Hi, I have a Day and Night roof top Heating and Air Conditioning Unit made in 2007 .
Model PGN3 My problem is when I turn on the heat nothing happens. I always used to hear a low humming when turning the heat on, and now nothing.The Air Conditioner works as does the Fan (separate from the heater) when I switch it on. I had the thermostat replaced last winter, when the heater was not working then. What happened at that time I would hear the humming noise when turning on the heat but no heat or air flow, Is it possible the heating element burned out from it being on for prolonged periods before having replaced the thermostat?
Hi, are there any error codes flashing, what is your source heat , gas ,oil ? What type of stat do you have ? can you remove the cover and jump out R &W , will the heat come on?
Geo 🇺🇸
Geo 🇺🇸
That model is under the Payne badge. It shows as a package unit.
Gas and and R22 3 phase A/C..... 2.5-5 ton.
Not sure about the 3 phase part on a house.
Model is shown as obsolete.
PGN3 manual (pdf)
PGN3 manual (pdf)
