Csst gas line
Old 02-25-21, 05:45 PM
T
Csst gas line
I am going to be running some csst to my furnace. I am looking at Gas flex and Pro flex. The Gas flex is about 1/2 the price of the Pro flex. The fittings are about the same price. Is one better than the other? There is already about 40' of black pipe that I would be connecting this to. Also, I know csst needs to be grounded. Can I run the ground wire from the black pipe to the ground bar fuse box or does it have to be on the csst fitting? Thanks
Old 02-26-21, 05:25 AM
Geochurchi's Avatar
Received 91 Votes on 86 Posts
Hi, which ever mfg. you choose should have specific instructions on how to ground and the proper connectors to use.
Gas Flex is not CSST ,
http://www.gasflex.com/products/
Geo 🇺🇸
Old 02-26-21, 08:35 AM
Grady's Avatar
Received 35 Votes on 33 Posts
Before using either one, make sure they are legal in your area & for your application.
