Comfortmaker RPJ II gas furnace
I was having the problem of the gas releasing but not igniting. I replaced the ignitor and it seems to be working fine but now the gas is not releasing when called for. I also cleaned the sensor and tightened the vaccum screw. Any suggestions?
So the hot surface igniter is lighting up and glowing?
Is the gas valve coil being powered? What is the voltage to the coil? What is the incoming gas pressure? And manifold pressure?
