Corrosion inside furnace around opening to heat exchanger
Old 06-28-21, 11:05 AM
Received 1 Upvote on 1 Post
Looking for some advice please... We have a couple relatively new high efficiency Daikin furnaces (2.5 years old). We are noticing an unusual amount of corrosion in one of the furnaces, specifically on the inlet plate facing the middle burner (picture attached) around the hole leading into the heat exchanger. There is no visible corrosion elsewhere on either furnace. We had a couple contractors come in and they weren't able to determine the issue. Wondering if anyone can shed some light on what could be going on. Any thoughts would be sincerely appreciated, thank you.
user 10 voted this post useful.
Old 07-05-21, 09:10 PM
user 10's Avatar
Received 51 Upvotes on 45 Posts
Can you post a picture of the exhaust/intake piping from that furnace?
I suspect exhaust which has acidic moisture in it is being recirculated back into the intake.
Termination done wrong.
Old 07-12-21, 05:52 PM
Thank you so much for responding. Below are a few pictures of the venting. There are two furnaces, the one with corrosion inside is on the right. It is the larger of the two furnaces (60k BTU). Any insight is appreciated!
Furnace on the right shows corrosion (facing middle burner). Intake is non direct, however, there is a fresh air intake from the duct on the left. Exhaust wraps behind the furnaces.
Furnace exhaust routes behind the furnace, then goes up into the basement ceiling and then travels approx 15 feet before venting outside.
Exterior furnace exhaust pipes for both furnaces.
Old 07-12-21, 06:03 PM
Received 3,422 Upvotes on 3,068 Posts
Neither furnace has a direct fresh air in line to outside.
Are you talking about fresh air from that flex line on the left side of the picture ?
Old 07-14-21, 08:02 AM
user 10's Avatar
So exhaust re-circulation is not the issue.
No easy answer.
Are you on propane or natural gas?
Do the flames look normal - no rollout, all of flame being pulled into each inlet?
Old 08-14-21, 01:23 PM
Thanks again user10.
The furnace is natural gas. Flames look ok to my untrained eye. Something that i thought of is that the furnaces share a relatively confined space with a water softener and extra bags of salt. When we were cleaning, we noticed salt on the ground, and salt dust may have been produced whenever the softener was refilled. Perhaps salt in air may be contributing to corrosion during combustion? We've since cleaned up the salt but will continue to monitor. Seems like a reasonable theory given that the other furnace with no corrosion is closer to the fresh air supply...
