FAN 24/7
Old 06-24-01, 06:54 PM
Guest
Question
IVE READ OVER AND OVER IN FORUM, TO LEAVE FAN ON 24/7. WILL THIS COST ALOT MORE?
Old 06-26-01, 03:08 AM
PDF
Less than
a dollar a day.If your fan motor draws 2-3 amps at 120volts,it would about 7500 watts or 7.5 KW.If you pay 7 cents per KW your cost could be closer to 50 cents per day.Plus I would imagine on cooler days a/c would not have to run at all.You only need to place fan on when you have those hot spots.PDF
Old 06-26-01, 06:04 PM
Guest
Smile THANKS
IVE HAD THE FAN ON FOR TWO DAYS NOW AND ITS WORKING TO HELP, KEEP THE UPSTAIRS, COOLER. IVE EVEN BEEN ABLE TO TURN THERMO. UP A FEW NOTCHES, THANKS
