Furnace thermostat help!
Old 08-31-21, 11:59 AM
B
I am trying to install a smart thermostat and need some help.
I am replacing a Honeywell wireless system (not wifi) and have one question and one issue.
First off I was pulling the wires from the module in the basement and noticed that each color can allow 2 different wires to be put in. I saw that there were 2 wires going into the Y Terminal (see photo). When taking them off to add to the wifi system I combined the 2 together and added a 3rd wire that goes upstairs to the new thermostat. What is the second wire?
I now have everything hooked up and going (1 stage AC and heater only 2 years old). The ac works perfect and comes on without problems the heat is the problem.
When I turn the heat on the exhaust fan comes on like normal. I took the panel off and watched the process by the blower. After the fan comes on the igniter glows bright red for about 5 seconds then goes off with the flames never starting. A few seconds after the igniter goes our the blower comes on and it started blowing cold air in the house. Does anyone know what is going on? Please help!
I am using the thermostat and have the fossil model selected instead of the electric.
I am using the ADC-S3000 thermostat, lennox furnace (95%), everything is 2 ton.
I ran 5 new wires because I had the AC installed a few months ago and they put in the wireless model.
I have a C wire, R wire that is put into the RH terminal (per manual), W wire, 2 Y wires (one ran to the thermostat) and one G wire. I used the photo above to go directly from model to model.
Both ac and furnace have water pumps as well.
Old 08-31-21, 07:58 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
Please post actual wiring pictures.
You ran a five wire cable. That is borderline as you need a minimum of five wires for a basic system.
Rc, C, W, Y, G.
You should be removing the EIM module or at least disconnecting it.
Do you mean condensate drain pumps ?
Those have no effect on the thermostat wiring unless you are connecting the safety overflow switches. If you are... let me know.
