Need new electrodes for a Model S Beckett oil burner. Yes, she's dated but she runs super. The contacts for the transformer no longer reach the contacts on the electrodes. Any suggestions as to where to obtain? Thanks in advance-
I'll see if I can find that locally, I've added a 10-32 coupler and a bit of 10-32 allthread to extend the contact springs, it works but it isn't correct. I'd rather find some new old stock if possible.
Hello all, I have a double wide trailer that has a Miller oil furnace. My problem is only heat comes out of half of my duct work. Heat only comes out of the ducts on one side of the trailer. I actually had a local company come out and check it out like 2 years ago. Of course I wasn't home and my girlfriend didn't really understand what they were talking about. Anyway the guy did tell her that all the ducts were hooked up as he had a camera he stuck down them. Any help is greatly appreciated as usual. Is my old pal Grady still a moderator?
[color=black]Heat cycle failure with fault code 34. Inducer motor does spin up for many seconds, I hear a click, then failure with the LEDs showing 34. I never see the igniter glow. I put a meter on the [u]igniter connector and don't see voltage[/u]. Was expecting it after that click. I did recently install a new igniter, hoping that was the problem. It still shows continuity, no short. Of course, no voltage to it, so it shouldn't be the problem. [/color][color=black]Limit switch also shows continuity. Gas switch is ON. Blew out all vacuum tubing, which seems ok. I'm still hoping it's not the control board.[/color]
