Suntec pump problem
Old 10-26-21, 06:45 AM
Suntec pump problem
Hi, I have a problem with an FBR FNP 45/2 TC oil burner that can't raise the pressure to 20 bar at startup. I have to set it from the regulator to 10 bar and after opening the electric valve I quickly raise it to 20 bar to ignite the flame. The pump is a Suntec E4na1070P with a flow pipe and a return pipe.
